I cannot open the .bin license key file
May 20, 2019, 11:22:46 PM *
Author Topic: I cannot open the .bin license key file  (Read 16319 times)
« on: June 23, 2008, 08:37:31 AM »
when you register a "key.bin" file is sent to you. This key.bin file is the license key for FDRTools Advanced. You cannot "open" it. Instead do the following:
1. Save the license key to a save place.
2. Download FDRTools Advanced from the Downloads page.
4. Install and start the program. A registration dialog shows up.
5. Within the registration dialog you can load the key.bin file to finish the registration process. Look at the bottom of the dialog. There you will find "License key" with associated "Browse"-Button. Press the "Browse" button, navigate to the place where you have saved the "key.bin" file and load it.
6. A message will appear confirming the successful registration.
You are done. The program will not produce watermarks any more.
« Last Edit: March 26, 2009, 07:44:59 AM by AndreasSchoemann » Logged
